how do i uninstall vista?
20 Oct 2002
London
I'm running XP, and had a trial copy of vista installed on another disk. I now want to completely delete it, but i'm unsure as to how best to go about that.
I tried deleting the windows / users / program files folders from within XP (the vista ones, obviously!) but got a load of 'access denied' type messages.
Any ideas? Formatting the disk really isn't an option as i have about 100gigs of stuff on there...
go to disk management and delete the vista partition.
then go to drive C, rename the "bootmgr" to anything to get rid of bootloader
that it :)
that it :)
hmmn, but if i delete the vista partition, won't i also delete the ~100gigs worth of media i have on the same partition??? :confused: I know i should have put vista on a fresh partition, but i couldn't be bothered to create one so i stuck vista onto one of my media partitions...
I can't really see anyway of gettting rid of it without a format of the partition. Isn't there space on another driver for you to copy the media to first?
eek, i suppose i MIGHT be able to find the space here or there...
what about if i used a special deleting program, which deletes stuff regardless of access rights etc?
Here you go. Load up your XP disc from start up and go into the recovery console.
Type 'fix boot' and type 'fix mbr' after you select the drive with xp on it.
Now as for those vista files;
Start in safe mode > Right click > properties > security > advance > owner > take owner ship and of that of all subfolders.
Advance> add > advance > find > user > ok > select rights for user, admin, system > replace permision on child objects > ok. Delete.
Those where my notes to remove a file that you get access problems for.
There is no need to reformat.
snow patrol said:
That does work. Hope you can work it out with my notes. You can't delete the file because you don't own it. All you are doing if making it your own to destroy it via security options only available to an admin in safe mode.
It is also very handy in reverse to make a file undeleable by other users even if they are admins.
I sometimes have to take ownership of my old files after reinstalling Windows as I get 'Access denied'... I've never had to do it from safe mode though.
I'm running XP media centre which is basically XP pro. I can't get into security sections wihtout safe mode on. How do you access it? If you know a shortcut I'd like to know.
PhilthyPhil said:
Go to properties, click on the security tab and click on the advanced button at the bottom. This is on XP Pro, I've never used MCE.
Ah, the security tab is missing on mine. Never mind.
