how do i use dvi ?
Permabanned
19 Dec 2006
my monitor has a hdmi/dvi input, and i have a gtx with 2 dvi ports.
Ive got my monitor working on vga, bought the cable today, turned monitor off, plugged hdmi cable into it, and into the gtx, and i get the grand result:
"NO SIGNAL"
bugger.
any ideas ?
cant find anything to switch between vga out and dvi out in the nvidia control panel either ?
No need to switch between DVI and VGA on drivers - however there maybe an option on the monitor - Change the Input / Source and see if that helps
yup i had done but the gtx wouldnt put a digital signal out (even though it was a hdmi-vga adaptor) untill i rebooted, which was wierd.
all sorted now.
Tempted to buy another screen to dual-monitor :p
