How do parked domains work?
Its a lot simpler than you think:
Code:
RewriteCond %{HTTP_HOST} ^www.domainname\.com
RewriteRule ^(.*)$ http://www.domainname.com/$1 [L]
That should do the trick.
Thought I'd pull this back instead of starting a new thread.
I've got two domains, the-iblog.com and the-iblog.co.uk. I have the .com forwarded to .co.uk, but I don't want the address bar to reflect this. I want it to still say.com if that's the site the came in on. How would I do this?
Thanks
Use the same example as above:
Code:
