- 27 Aug 2005
Hi Everyone. I got given an Amd Athlon 2000+ for free and I dont know if it works...
Anyway, I'd like to set up a budget system with it and i have everything except for MOBO, RAM, CPU COOLER and a power supply with a 12V 4 Pin connector. (Hopefully the CPU works)
I'm on a quite a tight budget..
How do you think these components sound?
MSI KT6-V SKT A AGP 5.1channel audio ATX
EB*Y*R 256MB DDR PC3200 400MHz 184pin Extra Value Ram Memory Module
Casecom 300W ATX Power Supply
Akasa Carnival Cooler 8cm Lo-noise Amd 3400+ Air Cool
In the case there will also be a 20gb HDD, a Geforce 5700LE 256mb gfx card, a CD-RW and a couple of case fans...
Do these sound ok?
Also does anyone know about overclocking this CPU the sticker on it says..
AMD Athlon
XDA2000DKT3C 9187726260016
AIUGA 0240RPBW 1999 AMD
Thanks a lot!
Do these sound ok?
AMD Athlon
Thanks a lot!
Whats 2000Mhz equiv too?
) then download OCCT. This will give you graphs of the VCore etc when the CPU is being stressed and show you if there are any fluctuations. I've never tried it with Socket A but I assume that it works ... anybody?
