how do u get picture signatures?
iCraig said:
Don't forget to optimise the image in a freelance pixel converter application before uploading, otherwise it won't work.
What? It will work fine if he makes it in any of the programs listed.
Nope, he needed to decompile it in a Rambo fragmenter otherwise the internets doesn't read it. I emailed him instructions and helped him.
budwizer said:
how did you make my sig though?
I searched Google for Budweiser lizard which turned up this image becasue I liked the look of Kell_ee001's sig. I saved it to my computer and opened up the GIMP. I run Linux so Photoshop is not available to me. Even if it were I wouldn't pay $1000+ to license it so the GIMP will do just fine. I cropped some of the black at the top and bottom then shrunk the whole image to 75 pixels tall. I selected a hand drawn area and shifted the text over so that the e was covered. Then I selected by hand the area around the S and flipped it horizontally. Next I expanded the canvas to 400 pixels by 75 pixels instructing it to leave the part I had centered at the far right. I added a layer of black and dragged it so as to fill the left area. I selected the green for the border with the eyedrop tool and used the pencil to draw the border at 1 pixel wide. I flattened it then saved it as png for quality and small file size. I uploaded it to my imageshack account and posted it here. :)
