I'm using OSX lion and having trouble with the delete function...
When I use a USB stick and plug it inI can "delete" the contents with *command delete* however it doesn't actually free up the space. It sends it to trash and still takes up the same amount of space so when I try and stick new things on it OSX complains there is not enough space left.
Am I missing a trick? Is it like most other things on OSX where it involves a rather convoluted option involving terminal or is there another key combination I should be using...?
I'm also having another issue. I installed some updates recently and now all the hidden files are now visible (such as trash and .Ds_store in every folder). How do I hide them again?
Thanks
Thanks
