Auto fill 0-360 in column A, enter the equation as a formula in B1 referencing A1 for the degrees value then auto fill down. Graph as normal.
Simples.
Thanks for the reply but given my formula and the question for my assignment it makes no sense. If I gave you the equation then I think I'd be in trouble so I can't explain it better
 see my next post)
 see my next post)You should get a sine curve alternating between V1=2 and V1=-2Thanks for the help but as a graph it just draws a mess of points. I'm not sure thats what he was after
 my mistake
 my mistake
yeah edited, I made a mistakeAlso my graph that I did get had a range of plus to minus two
 Excel works in radians not degrees
