See picture. That's what having five SSDs looks like when your case has no SSD mounting bays (that's an Antec 300 gen 1), but it's also indirectly because the SATA power connector was poorly designed and is typically quite loose, but SATA power leads are quite stiff, so it's hard to mount SSDs next to each other. If the leads are bent the connectors are prone to falling off.
Has anyone designed some sort of SSD cage to fix this?
Thanks
Thanks
