How do you keep the side window dust-free?
9 Jun 2006
Purgatory
I just got a new case yesterday, but I noticed the side window is already gathering dust. What's the best way to keep the window dust-free?
inside or outside of the case?
try dust filters for the inside
clean the room your pc is in more if its the outside
clean it every so often with a anti static cloth thing. erm it basically gets the dust off. make sure no pci brackets are open which allow dust in. a problem i have as i route a cathode cable out the back of case to a switch
The outside of mine was getting a little bit dusty, but after wiping it over with an alcohol wipe (the niceday ones) it is completely clear and has been for the last few days now.
Havent had a problem inside the case as yet which i am very happy about.
