How do you rate this monitor?
Well what do you recommend then?:rolleyes:
It'll be somewhat easier for people to recommend if you could list what kind of things you will be using the monitor for, priority wise (gaming, movies, work/web browsing) and what features you want or need (i.e. HDMI or DisplayPort). Also max budget, min-max screen size and resolution.
Have a look at this thread though for some 24" monitors I've looked at in the £170-£200 range.
The thread I linked to has my recommendations. A little look at the thousands of other related threads on the forum wouldn't go amiss - especially the thread Cracker links to which is a particularly good one.
Gaming, movies and some naughty stuff, max budget £180, 24" no bigger 1920x1080.
Cheers.:)
