Do people find that their first ram slot becomes obscured?
Also, on the heatsink, I find that the bits which you press to attatch the heatsink to the motherboard obscure the fan blades and if I had turned it on would cause it to not spin.
i've found that with the fan blowing through the scythe towards the exhaust at the rear makes very little difference between not even having a fan on the scythe.
2/3 degrees difference at most - not overly impressed with mine so far - might try lapping it and see if that helps.
