How do you solve the Chair vs Carpet problem?
Its called a chair mat, looks like this https://www.google.co.uk/search?num...0.0.100.652.8j1.9.0...0.0...1ac.1.x9EdIY3EcDU
Can get wood ones and plastic ones...you're welcome.
This ^
Though from experience i recommend against the plastic ones.
I was privately renting and did not want the pc chair ruining the carpet.
The plastic goes brittle and ends up splitting and cracking in places which sounds terrible when you move! also the little indentations underneath marked the carpet anyway!
Perhaps a wood one would be better.
Get decent carpet? I sit at my computer at least 8 hours a day and have done for years and my carpets fine. Though granted I am in the corner like a troll.
Be sure to cut your feet off though, they may wear the carpet while you're hangin'
a cheap low profile rug is imo the best option. will mean it doesn't make a nasty noise every time you move, wont move as easy either, and you can then replace after how every many years if it starts to look nasty.
another option would be buy a chair with more legs as then the weight will be spread better and do slightly less damage
