How do you use Bluetooth?
10 Jan 2006
Bournemouth tbh
Ok I have bluetooth on my phone.
I have something that i want to transfer from my PC to my phone via bluetooth, only thing is, I dont know how to use it.
In me settings on the phone, i have selected it and enabled bluetooth....
Nothings happening, am i supposed to see something happen? I notice an icon has apeared on phone, i have a SE W800i btw.
/waiting
You need to pair devices first.
I think what I did was get the phone to search for available bluetooth devices and it should find the computer. When you try to connect you will be prompted for a passcode on both devices.
You can send files to the phone using right click>send to>bluetooth>phone or send from phone through the menu via bluetooth.
You will need a bluetooth adaptor to send/recieve files to and from your pc, then you will have the "My Bluetooth Places" and then u should be able to get the right click send to blutooth feature.
A one of these?
Sitecom Bluetooth USB Adapter CN-500 - £16.99
With the Bluetooth™ USB Adapter you can experience freedom in the widest sense!
This extremely ingenious tool enables you to exchange data through your mobile Bluetooth™ telephone or exchange data between various PCs or notebooks with a Bluetooth™ USB adapter. To the non-private user, the Bluetooth™ USB adapter presents considerable advantages and flexibility; retrieve your E-mail while riding in a taxi, or surf the net on the train.
Wireless range = 10m
System Requirements:
Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP or later.
Bluetooth is a short-range wireless connection technology, not really included with PCs as it's designed for mobile devices.
Hence, you need to buy a Bluetooth adaptor much like you would any other network adaptor, and a USB-based one will work fine. Stick it in, throw in the drivers, pair devices, spend seven hours working out how to pair the devices, start again, re-install your corrupted Bluetooth stack, finally get connected, somehow get the phone coming out your PC speakers, and eventually you might be able to get it working :D
Depending on your phone, this is a very neat piece of software. Turns your phone into a totally customisable remote control :)
True_Scotsman said:
The K700i has the remote functin built in, u can even control media player :p
Unless the 700 is drastically different to my 600, Sailing clicker adds a helluva lot more and you can write custom scripts/actions etc...pause playing if I walk away from the PC, etc. Great fun :D
How true, how true, then you get it to work, then try again 3 weeks later and have to do it all again, wonderfull technology!
I use a Bluetooth GPS receiver with my PDA in the car, it always conencts without any intervention, why can't PC's and phones do this GRRRRRRRRRRR!
