ive benen told (which I believe to be wrong) that a laptop running a 1Gb stick and 2Gb stick will run Dual-Channel up to 2Gb and single channel over that?
rubbish surely?
Dual-Channel is setup at POST and either works fully or not at all
can anyone clear this up for me? i cant see why laptop or PC manufacturers do this as memory is cheap as chips and they are just disabling the speed of computer memory by half to save pennies.. as you know advertised DDR speeds only work when you have 2 sticks running at dual-channel... so laptops (or PC's) wit 3Gb of DDR 1066Mhz RAM will only be running at 533Mhz in single channel mode - doesnt make any sense to me to put 3Gb in any machine.. should be 2x1, 2x2 OR 2x4 ..never 2+1
the reason I ask is a friend has just bought a laptop really good deal, £249 for dual-core westmere Pentium 2.2Ghz with 667Mhz onboard GFX, 3Gb DDR3 1066Mhz memory, 250Gb HDD, wireless-N, Gigabit Ethernet, windows 7 64-bit and webroot security essentials free
ive told him the memory will only run at 533Mhz in single channel mode and if it were my I would spend £12 on a 2Gb stick to replace the 1Gb stick with giving him 4Gb and 1066Mhz
whats others thoughts on this?
thanks
rubbish surely?
thanks
