how does a computer work out a hexadecimal sum
Takes hex, internally converts into binary, does the arithmetic, displays results back in hex.
thought it was something like that thanks.
got an exam at 5 and not got any notes etc.
one think though i got an example here, its 5EH - 4CH. the H is upper case but is smaller than other figures and its sort of on the toe of E and C if that makes sense. what does that mean?
it cannot accept hex its binary!!!
it accepts a string of 1's and 0's and does some magic, then does some stuff to disply some other stuff on the screen (unless its not going to be displayed on the screen)
It means 5E is a hexadecimal number, like 21H is not 21 decimal, it's 21 hex (or base 16, not base 10)
H is not part of the hex character set which is 0-9 and A-F
So here we have:
5E - 4C = 12 hex
1011110 – 1001100 = 10010 binary
94 - 76 = 18 decimal​
Of course it takes Hex. You don't type a hex number in as binary do you?
got some other questions
describe two common types of micro controller architecture
a computer has 26 address lines. calculate teh total memory capacity available in Mb
