How does a Spyder calibrator work these days?
2 May 2004
I'm sure I read they used to get you to change your colours, brightness and contrast on your screen until they were right. Does it still work like that, or will it calibrate using Windows software now?
The reason I ask is I have 2 Dells at home, one of which is the U2410, so that'll have all the options, and another cheaper Dell which probably doesn't. Plus, if I'm investing £90 in a calibrator, I'd like to do mine at work as well (laptop screen + 2 random 24" cheap things).
Thanks.
