I'm having trouble with high temps on a 7950x build. I read somewhere that it's supposed to run at 95° but don't like it very much. I was wondering how under-volting and under-clocking can affect a multi-thread process. Will my renders take longer? I'll be happy to loose 10% performance if that means I can take my temperatures down to 60° on full load. My cpu runs by default at 5300 all cores all day but with those nasty spikes of +95°C. Also how does RAM speed can affect the same kind of workflow.
If there's no problem with underclocking and undervolting my cpu for rendering, should I have a different profile for gaming with high clock speed?
I work mainly with the V-Ray render engine.
Whole build is as follows:
-7950x
-Aorus Master x670E
-128Gb corsair dominator 6000mhz (3600mhz really please help with this as well if possible )
-Liquid Freezer ii 360
-Corsair 5000x case (without front and top glass)
-P12Max arctic fans x7
-4080 tuf oc
-Corsair rm1200x
-7950x
-Aorus Master x670E
-4080 tuf oc
-Corsair rm1200x
