- 7 Jan 2007
- Sussex, UK
As title, where does one start? I want a little more juice for bc2.
I'm using rivatuner and have just got GPUclock=756/mem=1100/shader=1512
I ran furmark for about 15 mins and max temp was 61C, with 60% fan speed.
That good? Is it faster than a GTX280?
Is your card a 260 216 core? If so that's a very good clock...and yes it's quicker than a stock 280
~660/1458 core/shaders will match a stock GTX280 give or take so that clock should put up as good or better performance.
Most GTX260 manage a max stable shader overclock of either 1458 and 1512, very few will do a core clock beyond 730-740 tho with complete stability. The gigabyte SoC and sparkle dual fan cards tho seem to hit upto 760/1570 with complete stability.
Might want to do some benchmarking tho as I've found that certain core and shader clocks seem to run faster or slower than others i.e. 720 core 1440 shader with 1200 memory seems to be the sweet spot for most of my cards not sure why unless they have some kinda strap relationship like the northbridge/fsb on some motherboards.
