how does physx work?
22 Oct 2008
Lisburn
I've read about others having a dedicated card for Physx but how do you set it up and how to you tell your PC to do physx stuff with that card and not your normal GPU? Sorry but I'm a bit thick when it comes to these things. Is there a physx guide anywhere worth reading? :o
Only applications that specifically use PhysX for physics processing can use the GPU for physics processing (currently) a lot of games like Bad Company 2, Red Faction, etc. use other APIs for physics such as havok and won't be able to use PhysX on the GPU.
