How does the Eizo foris fg2421 stack up against the current 1080p Gsync panels?
10 Oct 2012
Denmark
Was wondering how good or better perhaps the foris fg2421 is versus the acer or philip 27 inc 1080p gsync panels. I know that blacks must be better on the Foris but what about blur? Colors should still be better on the Foris right?
To be clear G-sync is not a feature i'm purchasing for, its only a bonus when everything else is been compared and will only be used if its a tie :). Im use to gaming at 120hz without vsync and have never been annoyed with tearing at this hz/fps combo.
I would avoid the Eizo monitor, quality control on those monitors are really bad, was my first purchase of a 120hz+ monitor and had to return it because of the colours, had a lot of backlight bleed and had a blueish hue to the edges of the monitor that was particularly noticeable while gaming. Wish I listened to all the other people that bought the monitor about the problems, would have saved me the trouble of having to return it.
I would also avoid. I got a bad copy with a well known fault down the right hand side (like light bleed but not exactly) and it had terrible ghosting/ smeary image in motion.
I got it from ocuk and had a truly terrible retail experience explaining the faults and sending it back.
Mine was fine, the blacks are very black but I really disliked the black crush and the colours were over saturated, the blur was very slightly worse than some of the TN 144hz panels, better once it's warmed up and set in 240 turbo. Not worth £400 now really as there's better out there imo.
