I am attempting to build a small powerful system to live under my television and connect in to my surround sound. Will be for light gaming and films. I already have a 256GB SSD. In particular does the power supply look reasonable?
Mini ITX PC Build
MEMORY: £53.52 8GB Corsair DDR3 XMS3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 11-11-11-30, 1.5V
CPU COOLER: £36.11 Noctua NH-L9i Low Profile Quiet CPU Cooler, Intel LGA1150/1155/1156
CASE: £28.86 Silverstone SG05BB-Lite USB 3.0 Sugo SFF mini-ITX Case All Black 120mm Silent Fan w/o PSU (SFX)
PSU: £43.56 300W be quiet! TFX Power 2, 80PLUS Bronze, Black, PCI-E, Sleeved Cables, ErP 2014
MOTHERBOARD: £89.96 MSI Z97I AC, Intel Z97, S 1150, DDR3, SATA III 6Gb/s, SATA RAID, PCIe 3.0 (x16), DP/DVI/HDMI, Mini ITX
CPU: £53.18 Intel Pentium K Anniversary G3258 S1150 Haswell Dual Core 3.2GHz, OC up to 4.5GHz, 5 GT/s DMI, 32x Ratio
GRAPHICS: £165.55 2GB Gigabyte GTX 960 ITX OC, PCIe 3.0, 7010MHz GDDR5, GPU 1165MHz, Boost 1228MHz, Cores 1024, DVI-I/DVI-D/DP1.2/HDMI2.0
Mini ITX PC Build
