Ok so santa rang me up and due to being very good this year wanted my xmas list!
So, i want to watercool my pc and also a new gfx card is needed due to the gf getting me a 22" monitor.
My budget is probabally no more than what is shown below - possibly pushed to £250 if needed.
How does the spec look? Anything you would change??
Thanks
Would you go for thicker tubing? As its just to cool my cpu there isnt going to be loads tubing to try and fit in the case? Anyone got a pic of different thickness tubing?
Thanks
