Been awhile (3+ years
) since I built my last PC. Only ever built a handful, so no expert here
. Time to build a newer, more up to date system with a bit of oomph!. Now, looking at the parts these days, all seems a bit daunting and scary
I'm trying to get a good solid board, that will give me as few problems as possible during build, yet runs well enough to keep up with the bigger boys. Something that will last a few years.
Choosing a MB has been the hardest part really, with many having issues with certain types of RAM or PSUs. Can you helpful guys take a look over what I've thrown together and see if you can spot any potential problems from the spec? RAM suitability, MB reliability, alternatives that fit/work better/cheaper yet provide best bang for the quid?
System will be used for occasional gaming and some video encoding. I'll be sticking with XP pro for now knowing the full 4GB RAM wont be seen/utilized till I switch to a 64bit OS. Holding off on Vista for as long as I can
Thanks
Your basket
Product Name Qty Price Line Total
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard £54.99
(£64.61) £54.99
(£64.61)
Sparkle GeForce 9600 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail Sparkle GeForce 9600 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £89.99
(£105.74) £89.99
(£105.74)
G.Skill 2GB DDR2 PK PC2-6400C4 (2x1GB) CAS4 Dual Channel Kit (F2-6400 G.Skill 2GB DDR2 PK PC2-6400C4 (2x1GB) CAS4 Dual Channel Kit (F2-6400 £27.99
(£32.89) £55.98
(£65.78)
Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB) - Retail Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB) - Retail £99.99
(£117.49) £99.99
(£117.49)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £59.99
(£70.49) £59.99
(£70.49)
Western Digital Caviar SE16 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) Western Digital Caviar SE16 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) £49.99
(£58.74) £49.99
(£58.74)
Sub Total : £410.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.95
VAT is being charged at 17.5% VAT : £73.65
Total : £494.53
.I'm trying to get a good solid board, that will give me as few problems as possible during build, yet runs well enough to keep up with the bigger boys. Something that will last a few years.
Thanks
Your basket
(£64.61) £54.99
(£64.61)
(£105.74) £89.99
(£105.74)
(£32.89) £55.98
(£65.78)
(£117.49) £99.99
(£117.49)
(£70.49) £59.99
(£70.49)
(£58.74) £49.99
(£58.74)
Sub Total : £410.93
Total : £494.53
