How does this look?
3 Apr 2009
Just need some help on ram, not to sure what to pick. Incase you was wondering want to eventually buy another 5850 wasnt sure if 650w would be enough?
Was thinking of getting i5 but not sure how much performance differance there is.
Yes, but you will need to use molex to PCI-E cables which should be supplied with the gpu, but not all manufacturers supply these.
I think that'l just be because a PSU without PCI-e connections is usually quite old or unreliable and they might not be able to supply the correct power. An adapter will give exactly the same as a normal connector as long as it's a quality PSU, which you selected.
so 650w or 750w? What would you suggest (just trying to save a bit if its not needed) remember will most likely buy another 5850 and will OC the i7
