In need of an upgrade to bring my PC out of the dark ages. I've only built one machine before - my current one, which has worked great for the last 6 years.
Current spec:
Epox EP-9NPAJ S939 Motherboard
AMD Athlon 64 3200+
2 x 512Mb Geil DDR Ram
NVidia 6600GT Graphics Card
Tagan 380W PSU (broken, system has been butchered to run on an old Dell PSU for the last 3 years)
DVD RW drive
Coolermaster Centurion 530 case
Windows XP
I'm not a gamer, so the system will be used for general internet/office use plus some video encoding. I'm also getting into photography so will likely use it for photo processing, plus iphone/itunes use and probably HD video/Blu-ray in the future.
I'm gradually moving more towards Linux as an OS so only boot windows up for itunes now.
I plan to keep my 6600GT for the time being as it seems fine for what I need, but if I upgrade, I will stick with NVidia because of the Linux support.
Budget is <£500, preferably <£400. Thinking about the below spec. (I may have a go at some mild overclocking, eg. clocking the 955 to 965 levels). It's unlikely I'll upgrade again for another 5-6 years so I want a system that will last! I'd like it to be fairly quiet, therefore I've picked a premium case (current mobo has a v. noisy fan and the case doesn't do much to keep it quiet)
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £117.49
(£99.99)
G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit
(£89.99) £105.74
Antec P183 Super Midi Tower Case - Gun Metal Black £104.99
(£89.35)
Gigabyte GA-880GA-UD3H AMD 880G (Socket AM3) DDR3 Motherboard
£89.99
(£76.59)
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £79.99
(£68.08)
Sub Total : £424.00
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 17.50% VAT : £76.39
Total : £512.89
Probably complete overkill, but it should last! Was originally looking at the Corsair 400W PSU but not sure how close to the limit this system would push it (plus any future GPU upgrade).
Opinions, please!
Thanks.
Current spec:
AMD Athlon 64 3200+
DVD RW drive
Windows XP
(£99.99)
(£89.99) £105.74
(£89.35)
£89.99
(£76.59)
(£68.08)
Sub Total : £424.00
DPD Next Day Parcel
Total : £512.89
Opinions, please!
Thanks.
Also if the CPU is under heavy load at any time (encoding etc) then the stock AMD cooler is LOUD! Included the extra Gelid fan as that case only comes with 1 fan as standard, but you can fit another one at the front for improved cooling.
