Will you be overclocking that? if not, you can get a much cheaper mobo, the IP35-E. If so you'll need an aftermarket CPU cooler and you should probably get the OEM version of the CPU.
Either way you can get by with much cheaper RAM. The OCZ PC2-6400C4 is the current best deal. You can also get a cheaper PSU. The Corsair 520 will do just fine.
Beyond that, I don't know if it'd fit in that case but I do know that it'd all work together all right.
