How does this spec look?
22 Jul 2004
Up north in Sunderland
Right have been on a budget and wanted to build full system, Already have a logitech mouse and got the mobo cheap from mm.
This is the spec I've put order in for.
Gainward GeForce GTX 460 GS 1024MB GDDR5 PCI-Express Graphics Card
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail
Asus M4A88TD-M EVO/USB3 AMD 880G (Socket AM3) DDR3 microATX Motherboard
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply
Intel X25-V Value 40GB 2.5" SATA-II Solid State Hard Drive
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM
Samsung SH-S223CBEBE 22x DVD±RW SATA ReWriter (Black) - OEM
Logitech Deluxe USB Keyboard (Black) - OEM
Antec 300 Three Hundred Ultimate Gaming Case - Black
What do you think? Will be used for gaming. (build thread to come)
its ok, would have changed the WD 640GB for a 500GB samsung F3, picked a 955be cpu over the 965be, and picked a slightly cheaper but still good PSU.
then a 60-64GB SSD could have maybe fitted in.
oh and picked the new Antec 100 case which is a few £ cheaper, looks better and has a black interior.
The price difference between the 955 & 965 is only £6 ~ at the moment so sitting on the fence.
Def change the HDD to the Samsung F3 1TB or 500gb.
should have mentioned I've got the case, Once again got it off of MM for £20 :D
Why would you pick the F3 over the WD? Just the WD looks to be quicker?
60gb ssd is £30 or so more.
Ah, I'll change that then cheers.
Looking forward to having a pc and not just laptop for the first time in 2 years.
If you make some of the changes suggested, including getting a 500w psu,then a bigger SSD is possible.
+1 I'd also pay that much as the 965 is better.
Apart from a 200mhz difference which can be reclaimed very easily, can you explain why its better please? Because im sure most people would rather have £££ in their pocket. :D
