Dreadi said:i dotn either, my 144 is cooled better on air then my mates 146 on water, and mine is clocked higher!
mortals said:isn't that image on a competitors website?![]()
no I just said that because it WAS now you've changed it. I didn't report it to a admin?geeza said:No.
were you the type of person that would be a snitch at school and get a kicking once a week?
Correct, and the water is also much better at transferring the heat away from the chip than a heatsink isMattus said:The radiator is gonna have a much larger surface area than an air heatsink would. This means that water cooling achieves better temps at the same noise level, or the same temps at quieter noise levels.
geeza said:No.
thank youRilot said:He saved you from a suspension so thank him
