How Does Your Phone Show a 3G Signal?
24 Sep 2007
Hi All
Not having upgraded my mobile for a while, I'm interested to know how modern phones indicate the 3G signal.
I guess all phones have a signal strength indicator, but can phones give the strength of the 3G signal separately?
Or is it that you just get your signal strength, and there's a separate 3G logo which toggles on and off depending if you're in 3G?
Thanks for any help and comments.
Rgds
With my BB 9700 if im in 3G coverage i get a 3G symbol...if im not in 3G coverage then the symbol doesnt show up.
Nokia S60 shows an antenna logo for 2G, an E for EDGE, '3G' for 3G and '3.5G' for HSDPA etc.
There's a separate icon below to display whether there is a data connection open
On my sony ericsson, i get a 3G when i have 3G signal and a seperate signal strength bar, or it turns to a H and a seperate signal indicator.
iPhone has a blue dot for GPRS, E for EDGE and 3G for 3G. Not sure about HSDPA actually, will have to go look into that one.
