How easy is it to fit a graphics card to a laptop?
11 May 2007
Ok, say for example I was to buy a Dell Vostro 1510.
It ships with either onboard graphics, or a 256mb Nvidia 8400M GS (64bit).
Now to upgrade it to the Nvidia costs £50, so I was wondering - what would be compatible with a laptop that is capable of an 8400M GS?
I fancy something a bit quicker.
Also, what other considerations are there? Power, overheating etc...?
Thanks. :)
Nope laptops cards are soldered onto the motherboard so you haven’t got a chance of manually changing it :)
You do get some upgradeable notebook graphics chips but typically only in higher end notebooks (i.e. ones with 8800M cards and such).
And even those theres a very limited upgrade path and usually it gets forgotten before the next generation of cards come out - so in reality its not really more upgradeable than any other laptop...
