Evening,
I recently built a computer for my cousin after i seemed to break his old AGP motherboard of an unknown cause.
Anyway, its got 4GB of Crucial RAM, a newer Core2 (the 2.0ghz 1mb cache one) and a 8800GTS(superclocked one) and obviously the CPU lets the system down at the speed its currently at. However, i want to overclock it to around 2.5ghz if possible, if not 3ghz would be great. His ram is currently at 667mhz on a divider instead on 800mhz because otherwise the system doesn't post with his P5E-SLI. However, the ram is 800mhz stuff. The multi of the CPU is 10x.
How do i overclock these? Do i simply upp the FSB and watch the VDIMM voltage and CPU Vcore as i go? I tried this before and it completely messed up the windows install (explorer crashing, nothing loading up etc) but that may have been a coinsidence.
Basically, ive only overclocked AMD's which seems a million times easier at the present time, but i know overclocking C2D are also very easy.
Thanks for any help and advice, as he has just bought crysis for his birthday and fears it wont run well at 1280x1024 with medium details, but i said it will if he overclocks his CPU.
