Suspended
- 9 Dec 2009
- Bristol
I presume the clutch is cable operated on the matiz? If so it will be mega easy to do.
Some hydraulic clutches have really weird positioned slave cylinders making them a right pig to bleed. When I did my Saab 9-5 the slave cylinder is built into the release bearing so you have to do a special technique to bleed it and only really know if it has worked once you have everything rebuilt. Any mistake and you have to take the box off again....
I would never do a clutch change without an engine hoist and a vast arrangement of hydraulic jacks though. I bench pressed an MX5 gearbox once and it nearly gave me a hernia.
@adam cool dude which generation on mx5 was this, and did you do the job with the car on stands?
