Pretty much... just disconnect the old LNB, pull the old LNB holder out of the arm on the dish, fit the new one (it might need tapping in), attach the new LNB, connect up, and away you go.
Try not to drag the dish out of alignment, or you'll have to line it back up again.
I replaced my standard LNB with an OCTLNB, was very straightforward, old one slid off (held with plastic pin which you remove first), slide on new LNB, reinsert pin and connect up your cables.
