- 11 Feb 2010
Motherboard: Asus P5B Wi-Fi Delux AP
CPU: Intel Core2 Duo E6600 2.4GHz
Cooler: Freezer 7 Pro
RAM: OCZ Platinum DDR2 4GB
Case: Jeantech Phong 2 with open vents on the side and fans front and rear
I've tried to overclock with the Asus AI Suite software and got up to 3.1GHz this afternoon but it isn't stable and this evening won't even sustain 2.6GHz for long. None of the temperature reports goes over 40oC either the RAM or the CPU. I've tried increasing the CPU frequency and leaving the multiplier at 9 with the Asus AI Booster but after a while the computer locks and the speakers squeal so I have to power down and go back to stock settings. Using the Asus AI N.O.S. software I can get a 7% boost at high demand, but it won't boot at anything higher than that. When I put this all together it was based on recommendations in the various magazines as to what would be good for overclocking without spending silly money and the theroetical max for my CPU I'm told is 3.8GHz, but I don't expect to get anywhere near that without spending a lot more on cooling. As it is my CPU ususally runs between 35oC up to 40oC, as does that RAM so I think my cooling should be good enough to get more out of the system.
Can anyone tell me what I'm doing wrong, or offer any advice on how to safely ramp up the performance closer to 3GHz?
Thanks for any help you can give.
