How far is to far to push voltage
20 Nov 2005
Redditch
Now my watercooling loop is finished & I'm happy with temps etc now is the time to decide whether to push my 4770k cpu further.
Currently it's sat at 4.5ghz with 1.27v (been that for 2 years) with temps around the 50c mark after gaming.
I tried some time ago when on an AIO cooler & achieved 4.8ghz with 1.35v which seemed stable in a few benchmarks & games.
Temps rose to high 70c, something I didn't want to run at 24/7 so dropped back to 4.5ghz
What I'm wondering is, is it worth pushing the chip to 4.8 - 4.9ghz with higher volts even though the temps will be lower.
I don't really think I'd see a noticeable performance increase from a couple of hundred mhz but I may be wrong.
Without delidding I would say it will be a struggle to keep your temps in check @ 1.35v, even under a custom loop.
You're not going to notice any difference between 4.5 & 4.8 so it's really down to whether you'd like to do it just because you can lol.
I run my 3770k at 5.1GHz with 1.35v. Completely over the top for how I'm using it but since it can do 5.1GHz I feel it would be a shame not to :D
Thats pretty much what I thought, but like you say it's just because you can, not that you need do. :D
I might give it a try over the weekend, just to see what sort of temps I get for a benchmark run, but stay at 4.5 - 4.6ghz for everyday use.
Nice one. You'll be safe enough up to 80c for a quick bench run. Maybe best to set up a couple of profiles, one for benching and the other for 24/7 clocks. Have you tried 4.6GHz at 1.27-1.3v? You might be using a tad more voltage than you need for 4.5GHz.
Yeah I tried 4.6ghz with 1.28v & it was fairly stable, but had the occasional crash when gaming.
I did have 4 sticks on memory at that time though which I later found was causing a bit of a problem.
I've since gone to 2x8gb rather than 4x4gb so may try it again.
Been having a bit of a play & found the following
4.6ghz - 1.29v
4.7ghz - 1.32v
4.8ghz - 1.38v
I can run firestrike slightly under these, but gaming requires the above to be 100% stable.
For the marginal increase in performace over 4.5GHZ @ 1.27v I think ill stay at 4.5ghz
However, i've found a couple of small gains with memory timings.
I've always run the at auto with X.M.P enabled, however for some reason at 2133mhz they default to 2T timings & 9-11-10-248 with 1.65v
Had a play & now have them running 2400mhz 1T 9-11-10-128 1.65v
Not much of a performance increase but every little helps if its for free! :D
I'm guessing there is more available from the memory, but overclocking memory has never been one of my strong points.
