27 Feb 2008 at 20:20 #1 qqg3 qqg3 Soldato Joined 11 Jan 2008 Posts 5,201 Location Nowhere I have an E2180 with 3 60mm fans and 1 120mm fan. How far do you think it will go? Oh and its with a stock HSF Other specs: Asus P5K-VM OCZ 2GB ATI 3850 Corsair 520 HX 400GB HDD
27 Feb 2008 at 20:21 #2 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,519 Location Antrim town Should be looking at atleast 3.2ghz unless you're using the stock cooler.
27 Feb 2008 at 20:21 #3 Monkeynut Monkeynut Soldato Joined 7 Nov 2007 Posts 6,858 Location Required Sure they aren't 80mm fans? You might get it to 3Ghz out of it
27 Feb 2008 at 20:25 #4 qqg3 qqg3 Soldato OP Joined 11 Jan 2008 Posts 5,201 Location Nowhere Nope, TT lanbox, came with 2 60mm and 1 120mm but I've added an extra 60mm. Would it worth investing in a Zalman or Artic Freezer HSF to keep things cool?
27 Feb 2008 at 20:28 #5 Chris Beard Chris Beard Associate Joined 17 Apr 2006 Posts 2,240 Location Hampshire About 20.32 meters.
27 Feb 2008 at 20:29 #6 qqg3 qqg3 Soldato OP Joined 11 Jan 2008 Posts 5,201 Location Nowhere Chris Beard said: About 20.32 meters. Click to expand... Thats hilarious
27 Feb 2008 at 20:30 #7 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,519 Location Antrim town Try it with your current cooler. But you may have to go for something like the AC Freezer.
27 Feb 2008 at 21:05 #8 mks2005 mks2005 Associate Joined 27 May 2004 Posts 2,400 Location UK Mine does 3.4 now.
27 Feb 2008 at 21:35 #9 uv uv Soldato Joined 16 May 2006 Posts 8,436 Location Manchester mine posts at 3.95, boots at 3.7, is stable at 3.4, but it's too hot, so I use 3.2 they're *damn* good for the peanuts you pay!
28 Feb 2008 at 10:45 #10 The Badger The Badger Associate Joined 8 Oct 2007 Posts 1,369 I got mine too 3.0ghz with ACF7 , havent been able to get it passed that. ive just switched over to water and havent tried again
