How fast is your TomTom?
18 Oct 2002
Overground, underground..
As is says on the lid - benchmark your TomTom (or other satnav system)
Route start - John O'Groats
Route end - Land's End
Use fastest route option, avoid toll roads (shouldn't be any)
Start your stopwatch when your device start planning the route, stop it when the device is 'Done' edit: ie after it's finished writing the route instructions
State TomTom version number, map version.
Qtek 9000 (aka Imate JasJar, Orange M5000 etc)
CPU - Intel PXA270 @ 520MHz
TomTom v5.210, map v605
memory card - Kingston Elite Pro 1GB
In portrait orientation - 1m26s
in landscape - 2m46s
Orange SPV C600
CPU - TI OMAP850 @ 195Mhz
TomTom v5.200, map v605
memory card - Kingston miniSD 512MB
2m13s
Nokia 6670
CPU - hmm 200mhz iirc :/
Standard TomTom 5.0
mobymen 512 minisd card
1:43
route: 14:23 hrs - 837m
gets stuck for ages on 130m to go
Tom Tom Go 700 Ver 5.420 & Maps Western Europe Ver 6.06.
76 Sec's to calculate and write the route on first run.
Powered off the TTG and re run the route as before this time 35 Secs so it must cache previous used routes.
T-Mobile MDA Vario/I-Mate K-Jam/Qtek 9100/Orange M3000
Tomtom Mobile 5
Unbranded 1Gb miniSD card
Unsure of the map version
A stonking 58 seconds (uncached!)
I'm very surprised as this phone is normally pretty slow at less than 200Mhz :eek:
Tomtom Mobile 5
How do you get the map version to display?? (Pretty new to TomTom)
Tap the GPS signal strength indicator in the bottom right corner, or go through the 'Change preferences' menu to 'Show version'
Heh! Opps, i didn't see the map version listed in there. I only thought it quoted the app version and that was it.
Ah well, on with the test....
Orange SPV C500
1GB SanDisk MiniSD
TomTom 5.2
Maps 562
837Mile route....
167.028 seconds (didn't have a stop watch on me so i quickly knocked on up in VFP).
Phone: Nokia N73
TomTom: v6.010
Map: v650.1046
SD Card: Corsair 1GB miniSD
Time: 10s
But then this thread is rather old, so that's only fair that it doesn't take too long.
InvG
TomTom 710,
Tomtom V 6.524
Map Western_Europe v650.1047
1GB SD Card, Tomtom stickers over the brand.
Time: <12 seconds.
Route, 14:35 hours, 836 Miles.
