Well our VP450P can run a GTX Titan perfectly fine, running on a Gaming 5 Z97 Gigabyte board with an Antec AIO watercooler. All running at stock, if you overclock I'd suggest looking for something a little more juicy.
Titan Killer - BUY NOW!
The VP450P is crafted for quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkly lights or glittery paint jobs - a 120 mm fan for effective and quiet cooling, dual +12V rails for amazingly stable power, heavy-duty protection circuitry and active Power Factor Correction (PFC) that saves money on corporate power bills. And it comes with all the assurance of Antec's AQ2 Antec Quality 2 year limited warranty. All the features, none of the waste: for builders that are strictly business, the VP450P is strictly power.
Features:
- 450 watts of Continuous Power
- ATX12V version 2.3 compliant
- Dual +12V rails ensure greater system stability
- EuP 2010 compliant assuring efficiency and low standby power consumption
- Active Power Factor Correction with PF: 0.99 for higher efficiency and less power grid pollution
- 120 mm fan delivers quiet, reliable cooling
- Black exterior complements any system
- Heavy-duty protection circuitry prevents damage from a variety of dangers:
- Over Current Protection (OCP)
- Over Voltage Protection (OVP)
- Short Circuit Protection (SCP)
- Over Power Protection (OPP)
- Safety: CB,TÜV,C-TICK,CCC,CE , Gost-R
- MTBF: 100,000 hours
- AQ2 Antec Quality 2 year limited warranty on parts and labor
Features:
