Yes im a total car nub before anyone comments
I have a simple question. Ive just had the car ( focus 1.8 collection 2001 y-reg ) moted and taxed and ive had an advisory on the pads and discs, front only as its not ABS the back drums and shoes are fine.
Ive been quoted approx £200 for standard ford parts ( fitted ) and tested. They claimed to properly clean and fit the discs/pads takes 2.5 hours so a lot is labour costs.
Ive just priced up standard ford discs and pads and its £76 delivered, and thats just the first place i looked.
So how hard is it to do myself? i have no tools but i have a friend who is a motorbike nut and im quite sure hes got the kind of kit we need. Hes on holiday atm so i cant ask him if hes done this before, though i bet he has.
Is the garage scaring me with the old "if not done by a professional your wheels will come off and you will die" routine?
Of course i know that brakes and wheels arent things to take lightly in regards to safety but saving myself £120 by doing it myself seems daft not to consider.
