AcidHell2 said:not difficult but very time consuming. You have to attach the cable to the engine, sometime harder than you imagine. You have to run it though the bulk head, also have to take the dash appart to get to the back of the spedo. Thats if its cable.
jumpy said:Probably 25 quid per hour labour minimummost likely more if it's a main dealer type garage.
meh, win some, loose some...JRS said:Look at his location mate -
merlin said:Bear in mind no worky speedo may well mean odo has frozen.
Ask how long the speedo has been out of action.
JRS said:Look at his location mate - prices in AUS$ would probably be closer to the mark
Changing speedo cables isn't all that difficult, but it can be very time consuming on some cars.
Ukadder said:Well it means that the car could have done X,000+ miles more than the odo is displaying, which could be bad if the car is advertised with lowish miles and it's infact done a lot more.
Not bad for a Supercharged MK1 if you ask me.Enfield said:£2,500 for that? Bloody hell!![]()
They did in Japan.merlin said:Toyota did not SC that car.![]()
