- 12 Feb 2006
- Surrey
looking for some advice. i will be getting a few quotes, but i'm considering doing this myself as it will be months before we can afford to pay someone any way, so may get it done quicker if i can do it myself with a brother as then it's just the parts needed.
i'm looking to replace the current hot water tank with a slightly larger one, and then bring all the pipes and equipment that is on the left side, bring it to the right inline with the tank and above it, so that we can then one day have a built in wardrobe built around it without pipes stick out the front.
anyone know how easy this should be?
i'm also considering moving the tank into the loft, but told against this as it's more work, and the cold water would need to be raised. doesn't seem so much an issue to me personally, and is better as then the tank is gone from our room, but then i am not experience with this.
