I'm looking to stand mount a pair of Q Acoustics 2010i as rear surround speakers and wondering how tall the stands should be.
On the one hand, logically ear level is optimal height and that's what most sources suggest. However, that hight would mean the speaker is partially blocked by the back of the sofa.
The other option is getting a taller stand that will let the speaker clear the rear of the sofa, but then it's not going to be at listening level as recommended.
I'm my case, an 80cm stand with the 30cm tall speakers would be at listening level (Pixel T80 seems good). But a 100cm stand would let the speaker clear the back of the sofa (Atacama Nexus 10i possibly).
Or does none of this matter too much if your AVR has room EQ optimisation? Will that adjust well enough accordingly? I'm planning on getting a Marantz with Audyssey (I need a slim AVR).
Interested to hear anyone's experience and recommendations. Ideally, in either case I want a decently weighted stand without worrying about toppling over and with cable management (I have a cat).
Thanks
Thanks
