27 Aug 2009 at 22:15 #1 Temi_D Temi_D Associate Joined 31 Jul 2009 Posts 2,237 Location 127.0.0.1 If i install a mobo without an i/o shield is it dangerours or does it have any adverse effects?
27 Aug 2009 at 22:40 #2 JonJ678 JonJ678 Soldato Joined 22 Dec 2008 Posts 10,369 Location England Not very. Its a good thing to have in terms of grounding/shielding, but if you dont use it no great harm should come to you. If you've got one, use it. If not, ignore it or try to get the manufacturer to ship you one
27 Aug 2009 at 22:44 #3 Uriel Uriel Soldato Joined 15 Jan 2006 Posts 7,814 Location Derbyshire Easy way for dust to get into the case if you run with negative air pressure. I run my second PC without one.
27 Aug 2009 at 22:53 #4 Sniper Ash6 Sniper Ash6 Associate Joined 24 Aug 2009 Posts 156 Uriel said: Easy way for dust to get into the case if you run with negative air pressure. I run my second PC without one. Click to expand... That was pretty much what i was going to say regarding dust As well as making it easier to plug things in "blind" as if you miss you normally hit the backplate - but thats more a minor problem
27 Aug 2009 at 23:01 #5 Temi_D Temi_D Associate OP Joined 31 Jul 2009 Posts 2,237 Location 127.0.0.1 Oh ok thanks guys. I was thinking that it was more of a use it or die scenario
