- 5 Dec 2013
Hi there. I'm new to the forums and also new to making my own gaming PC. I have had help from my friend and my brother in this build but would like to know some expert advice. Please can you rate my build and chosen components (whether they will work well together or not) and tell me if I need to improve on something.
Here is my build so far: CPU - Intel Core i5-4670K 3.4GHz Quad-Core Processor
Motherboard - Asus Z87-A ATX LGA1150 Motherboard
RAM - Kingston Blu Red Series 4GB (1 x 4GB) DDR3-1333 Memory (x2)
SSD - Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk
HDD - Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
GPU - MSI GeForce GTX 760 2GB Video Card
Power Supply - Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive - Lite-On iHAS124-04 DVD/CD Writer
Case - Zalman Z9 Plus ATX Mid Tower Case
My budget was £700, however I did go £20 over which isn't too bad (since I can handle it).
My brother has also said that he may help me in getting a GTX 770 instead of the 760 which I chose so if someone could "review" the build with both GPUs that would be great
(this is the 770 he picked out) https://www.overclockers.co.uk/showproduct.php?prodid=GX-178-GW&groupid=701&catid=1914&subcat=1750
Thank you for helping me out
