How is this spec incl monitor
25 Dec 2010
I'm not getting much traffic in the other forum, so I thought I'd try here:
Hi,
I'm looking for a PC that I can use primarily for:
-Playing poker (12-16 tables and running intensive database programme based on SQL, so need separate SSD) would also like a 27" monitor with a res of 2560x1440
Other uses will include:
- Watching movies
- Dual screen set up
- Playing music
- Intensive browsing using FF or Chrome
Aside from the SSD and the monitor, I wouldn't anticipate that this is an expensive rig, so my budget is actually:
£350-400 for the PC and upto 200 for the monitor.
Thanks
YOUR BASKET
1 x Hazro HZ27WiE 8-Bit 27" Glass LED Widescreen Professional Monitor - Black £299.99
1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £82.99
1 x MSI HD 7770 GHz Edition 1024MB GDDR5 PCI-Express Graphics Card £65.99
1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) £55.99
1 x Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/8X) £45.95
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Asus H81M-PLUS Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard £40.99
1 x Antec VP450P 450W '80 Plus' Continuous Power Supply £35.99
1 x BitFenix Merc Alpha Gaming Case - Black £32.99
Total : £704.87 (includes shipping : ).
