Pretty much straight away iirc.
Collinite 845?
collinite is tough stuff
reportedly can last up to 6 months if applied correctly.
Not a particularly high shine wax however, more protective than shine enhancing.
That's the job of a wax. Waxes don't really "add" shine so its always good to go for a good lasting one.
So what would you use on a dark (lapis) blue Boxster? I'm currently using SRP EGP and am happy with the shine but it never lasts more than a day or two.
Would a liquid polish, such as the Megs one, have the same results as I'm currently having? Would I be better of using a past like wax such as Collinite 476s?
personally i dont buy the whole "certain polish / wax combo is better for certain colours" thing.
use what your using now, theres nothing wrong with it.
Most who use collinite use it during the winter for protection from salt and road grime.
