Absolutely, I had an old Supermicro dual PIII board that I bought probably 8-9 years ago (which a friend has been running 24/7 for the last 6 yrs) that only died the other month. The 1.2GHz Athlon that replaced it is still running strong.speedy2004 said:Or is that like saying how long is a bit of string?
clocka said:they tend to last longer the less you change settings in bios i find. if you changed things everyday and reset cmos everyday i reckon it would die a lot quicker than an identical board just being changed once.
you should get a few years out of it tho, make sure no dust gets in your computer too.
ghgh said:ive got a gigabyte ga6bxc slot 1 motherboard with a p3 450 @ 600 and it still works totally fine. Thats from before 1999 I think. At college we have 486s that still work totally fine and lots of original Pentiums.
