) and see if they they will swap it out. I have been in similar situations with things like caps broken off cards on arrival before and always got the seller to send me a replacement. BFG returns have been mentioned on here a few times so a search could give you some more info on gueestimate times should you have to go that way
. It is entirely up to you but if you have taken pictures and could possibly add a date stamp in to them you could keep them for any return purposes I suppose should they quibble. However, I am wondering what happened to it in order for that bend to have got there in the first place as doesn't look like the lightest of taps....
. Hopefully everything is fine
.I just don't know, that gauge of metal isn't all that weak and the damage looks fairly focused, dropped by one of the packaging monkeys at the manufacturer perhaps before it went in to the box? Not meaning to be negative, I just don't want the blame if you fix it and there are problems down the line. Hopefully everything is fine
.RMA "down the line" then if problems occur
Though trying to RMA the card later on may be harder due the possibility that the damage will be put down to you. If the OP has any doubts the card may be damaged - i would RMA it right away.RMA "down the line" then if problems occur
