How long for TIM to work optimally?
31 May 2005
Nottingham
Just installed X2 4200 and Freezer 64 PRO.
CPU temp idle is 43c which seems a little high to me.
How long should I give it before I reseat the CPU?
Reset the CPU?
It should be optimal from the very moment you put the paste on the CPU, to the first boot up.
when i built a couple of AM2 rigs with very similar processors and the same cooler a month ago, we were getting Idle temps of about 24c. yours sounds very high. improbably high, even.
though, is this a bios temp or a windows temp. On-die temp sensors are rearely accurate. yours might just be less accurate than normal.
Also, are you sure the cooler is properly attached? it might not be getting optimal contact.
