How long is a 2900xt?
11 Apr 2004
In Christ
As the title,
I just would like to know the length of the card please, so I'll know if it'll fit in my case.
I cant seem to find the dimensions on any site.
Thanks
The only answer you need is LONG.
In my Coolermaster ATCS-201-SXK, the card is long enough to touch the SATA connectors on my HDD's. :(
It only just fits.
Its as long as your motherboard is wide. The power cables plug in the side too, so the length isn't artifically increased that way.
In essence it'll fit in any case that supports an ATX motherboard. Worst case (no pun intended ;) ), you have to relocate your HDs if your case is extremely cramped.
Its true, its only due to me having 4x HDD's in a RAID array that makes my case so cramped.
